Browsing this Thread:
a15 piston size?
From north brissy
i've had to bore my a15 too 79mm which i believe is maximum i was just wondering what pistons could now be used as standard units dont go that big
Posted on: 2006/8/2 7:34
Re: a15 piston size?
Did you actually bore the engine without having pistons for it first?
Most people seem to use Mazda pistons & I think that the MX5 engine is the preferred donor. Hopefully others will either confirm, or set the record straight.
Posted on: 2006/8/2 8:55
Love your Datsun.
Treat it well.
From north brissy
well no i havent acually bored it yet but i will be and the info i found was subaru justy pistons but i'll look into the mazda ones, thanks.
Posted on: 2006/8/2 9:13
From brisbane
mazda e5 pistons will fit with some mods like machine small ends but the biggest problem is head gasket size. One other thing, the larger the bore size the thiner the bore which can pose problem in big horsepower engines.
Posted on: 2006/8/2 10:25
1972 Datsun 1200 Coupe A15 Nos
1978 Datsun 1200 Ute A15 Turbo
