Help please
I'm changing the timing belt on my Ca. But can't get the big bolt undone. in the front of the crank.
I tryed a rattle gun, next is a big pipe and a socket.
How can i hold the thing to undo it? i have no tail shaft in to hold it.
Any ideas please.
Posted on: 2006/8/5 11:03
Re: Help please
From Brisbane
a bolt in where it bolts up the gearbox and a large screw driver in a notch in the flywheel, does this make sense? (i had a few wild turkeys)
Posted on: 2006/8/5 12:33
Re: Help please
From Adelaide. SA
Hey there, Put your socket on the bolt with a long solid bar or ratchet, move it around till its resting on the ground on the left hand side (under the car). Turn the car over with one quick flick of the key. This should be enough force to undo the bolt. Make sure there is no one standing in the way that could get hit!!
Cheers. Adam.
Posted on: 2006/8/5 23:22
Re: Help please
Thanks i will give it a go.
Posted on: 2006/8/5 23:32
Re: Help please
Thanks, it worked great.
New timing belt and water pump in now.
Not much left to do now.
Posted on: 2006/8/6 9:37
Re: Help please
From Sydney, Australia
I learn the bar against the passenger side chassis rail. Happy to hear it worked.
It is a magic technique.
Posted on: 2006/8/6 9:40
