datsun 1000 engine compartment
Quite a regular
From BRITISH COLUMBIA.CANADA
do these 1000s have the same size engine compartment as the 1200s ??
Posted on: 2006/8/6 7:43
Re: datsun 1000 engine compartment
From SE Melbourne
Nope - the 1000 doesn't even have strut towers!
Posted on: 2006/8/6 7:44
Mildman, Datsunless
Quite a regular
so does the 1000 have more room than the 1200??
Posted on: 2006/8/6 7:49
From Perth
Width to a point yes
Length I think the 1200 is longer
But firewall mods aren't that hard to do to get the engine setback
Depends what engine your trying to stuff in there
Don't want anything too heavy
Posted on: 2006/8/6 8:01
The engine bay in a 1000 has more available width as it doesn't use pogo stick suspension, so there are no suspension towers to take up room in there, but it is not as deep from crossmember to the underside of the bonnet.
The air cleaner of a stock 1200 engine will rub on the underside of a 1000 bonnet.
The length is pretty similar to a 1200 though.
If you are contemplating something with overhead cams, remember that these engines can be a bit tall. Measure thrice to avoid un-necessary expendature & lots of quiet sobbing.
Posted on: 2006/8/6 8:03
Love your Datsun.
Treat it well.
From Sydney Australia
The 1200 has more room up top but lower down the transverse leaf gets in the way and it becomes skinny.
Quite a regular
im thinking of putting a 82 toyota 1.8 3tc hemi motor in there.
Gary
Posted on: 2006/8/6 8:04
garys1000 wrote:
toyota 1.8 3tc hemi motor.
Gary
Hemi? Sounds like a Chrysler wannabee.
I have only ever heard this term used in relation to that companies all alloy V8 design from the Century series of cars & these were a pushrod design, inspired by [but not copied from] the 1953 Dodge hemi.
What cars used these 1.8 Hemi engines? I'm guessing that it's a 4 valve DOHC 4cyl design but I'm not too well versed in these brand X engines.
Posted on: 2006/8/6 8:54
Love your Datsun.
Treat it well.
Quite a regular
you can find these engines in 1980-82 toyota`s
Posted on: 2006/8/6 18:38
From Newcastle (NSW)
Has anyone managed to fit an L16 into a datsun 1000 ???
Posted on: 2006/8/7 1:02
