#1 datsun 1000 engine compartment
garys1000 Posted on: 2006/8/6 7:43
do these 1000s have the same size engine compartment as the 1200s ??
#2 Re: datsun 1000 engine compartment
Mildman Posted on: 2006/8/6 7:44
Nope - the 1000 doesn't even have strut towers!
#3 Re: datsun 1000 engine compartment
garys1000 Posted on: 2006/8/6 7:49
so does the 1000 have more room than the 1200??
#4 Re: datsun 1000 engine compartment
dattoman_1000 Posted on: 2006/8/6 8:01
Width to a point yes
Length I think the 1200 is longer
But firewall mods aren't that hard to do to get the engine setback
Depends what engine your trying to stuff in there
Don't want anything too heavy
#5 Re: datsun 1000 engine compartment
Dodgeman Posted on: 2006/8/6 8:03
The engine bay in a 1000 has more available width as it doesn't use pogo stick suspension, so there are no suspension towers to take up room in there, but it is not as deep from crossmember to the underside of the bonnet.
The air cleaner of a stock 1200 engine will rub on the underside of a 1000 bonnet.
The length is pretty similar to a 1200 though.
If you are contemplating something with overhead cams, remember that these engines can be a bit tall. Measure thrice to avoid un-necessary expendature & lots of quiet sobbing.
#6 Re: datsun 1000 engine compartment
Ianey Posted on: 2006/8/6 8:03
The 1200 has more room up top but lower down the transverse leaf gets in the way and it becomes skinny.
#7 Re: datsun 1000 engine compartment
garys1000 Posted on: 2006/8/6 8:04
im thinking of putting a 82 toyota 1.8 3tc hemi motor in there.
Gary
#8 Re: datsun 1000 engine compartment
Dodgeman Posted on: 2006/8/6 8:54
garys1000 wrote:
toyota 1.8 3tc hemi motor.
Gary
Hemi? Sounds like a Chrysler wannabee.
I have only ever heard this term used in relation to that companies all alloy V8 design from the Century series of cars & these were a pushrod design, inspired by [but not copied from] the 1953 Dodge hemi.
What cars used these 1.8 Hemi engines? I'm guessing that it's a 4 valve DOHC 4cyl design but I'm not too well versed in these brand X engines.
#9 Re: datsun 1000 engine compartment
garys1000 Posted on: 2006/8/6 18:38
you can find these engines in 1980-82 toyota`s
#10 Re: datsun 1000 engine compartment
qik1000 Posted on: 2006/8/7 1:02
Has anyone managed to fit an L16 into a datsun 1000 ???
