Re: A series engine weaknesses
From Sydney
I've been driving A-series engines for 9 years now and have never had any engine issues what-so-ever - and I abuse them. All I do is change the oil and filter every 3 months.
Besides that I have one quick question - if your car spends a lot of time sitting in traffic its a good idea to fit an oil cooler right?
Posted on: 2006/8/7 4:49
Every dog has it's day... except hyundai's.
Posted on: 2006/8/7 5:16
Iv never found any major faults with the A series Iv run 30 psi/6500 rpm in it for 6 years and only had one problem with corosion in the head.
saying that iv also got a 240z triples, race cam blah blah blah and i reckon the old l series is pretty damn good too.
I belive the A series was moderized version of the old Austin/Morris A series and the L series was a version of a mercades six.
Posted on: 2006/8/7 8:42
The J series Datsun was developed from the Austin engine, & an OHC Toyota Crown six engine was derived from the Benz as far as I know, but both the A series & the L series Nissan/Datsun engines were clean-sheet-of-paper designs.
Posted on: 2006/8/7 8:50
Love your Datsun.
Treat it well.
From Christchurch NZ
qik1000 wrote:
Well, here's my two-bobs... I agree with a lot of whats been said already, and disagree in some instances. My experiences have been with a race prep A15 and as such only relate to that - not a street or stock motor!
We have broken quite a few head bolts - we were using NEW nissan bolts over tensioned to avoid blowing head gaskets. We've moved to new class 12.9 cap screws for all head bolts except the unusual bolt for the oil flow. For this one we use a new nissan bolt but don't use it for any more than two head bolting applications.
We've broken one crankshaft. We got four years of racing out of that one and expect to replace cranks now every two years.
We've always used old rod bolts with standard tension and (touchwood) haven't yet had a failure. But I feel we've been very lucky although we don't use them more than two applications in race use or two years.
We've also never thrown a flywheel. Other people we race with have thrown them on more than one occation. We over tighten them as well and use new class 12.9 cap screws. Same on the clutch, but I think thats overkill.
the main pulley seems to be cracked every time we pull a motor apart. The key that drives it actually widens the keyway in the crank and causes a local increase in diameter in that region which cracks the pulley through a corner of the keyway. None have come off completely but they don't last long. I'm going to make a new one from a tougher material than the original cast iron.
Hope my experieces can help in someway!
Daniel.
EDIT: Oh yeah, pistons don't have a real long life either in our engines. But they have traditionally been machined down mazda pistons. I'm currently trialing a different idea at the moment!
I don't know if this applies to the "A"'s, but I have heard on some engines that overtightening the head bolts can deform the bores and lead to redued ring sealing. (This was on some crusty old ford engines)
If you've cracking the front pulley, that's a harmonics thing. When I missed a shift with my old S/C A14 and over reved it BIGTIME, the flywheel came loose. When I went to reuse my custom aluminium front pulley on my new engine, I found the keyway had split.
I'd use a custom harmonic damper like D/Man's, but my pulley system wont accomadate it.
Posted on: 2006/8/7 9:39
Forced Induction!
« 1 2 3 (4)
