« 1 2 (3) 4 5 6 ... 8 »
Re: Gearbox fill bolt - stuck!
From SE Melbourne
The bolt is pretty much perfectly square....so my sockets, that are designed for a hex head, don't seem to be as useable.
I've got some pipe in the boot, I think I'll stick that on the end of my bug kincrome shifter and hope it doesn't round the nut.
Posted on: 2006/8/6 6:57
Mildman, Datsunless
From Brisbane
with my CA box, the only way i removed the filler was welding a 1" nut onto and 2 blokes using a foot long ring spanner, it was ridiculous how tight it was, that's the way i did it. while it was still hot from welding. i had a spare to replace it with
Posted on: 2006/8/6 8:42
Yes, use a plumber's pipe wrench. A big one. It will come out.
Posted on: 2006/8/7 5:32
From SE Melbourne
I guess you mean one of these puppies.
Posted on: 2006/8/7 6:46
Mildman, Datsunless
Quite a regular
From Brunswick, Melbourne Australia
Yeah, but wid a big fat pipe hangin off da end ov it!
Posted on: 2006/8/7 11:49
From SE Melbourne
So I got some pipe, put that on the end of some spanners....no good. I belted the #### out of the system with a hammer...no good. I went out and bought a stillson wrench, pipe/hammer/shitloads of torque - no fcuking good.
I'm done - I'll pull the gearbox out and get someone to weld a nut onto it. I've got a spare fill plug to stuff in there.
Crap.
Posted on: 2006/8/12 13:19
Mildman, Datsunless
From Taupo New Zealand
Did you try heating the aluminium before swinging on that stilson? Some bolts seem like they will never come undone and then with a little heat- easy! and especially with a steel bolt in aluminium as the ali expands much faster than the bolt will.
Posted on: 2006/8/12 22:58
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Charlevoix, MI USA
Once you've got the bolt out when you reinstall it, apply teflon tape to the top 2/3 's of threads. This has ensured a good seal and easy removal for me when reservicing.
I do this for the drain plug and diff as well.
Posted on: 2006/8/13 3:18
"from the land of the graceless bumper"
'78 B210GX BREwannabe'
From SE Melbourne
Good thinking their Longbrow will do that - I've teflon taped the oil pressure sensor, but hadn't thought of that for these bolts.
I'll give the bolt a heat for one more try....better than removing the gearbox just for this filler bolt.
Posted on: 2006/8/13 8:44
Mildman, Datsunless
ben, since when do a series gearboxs need oil
as Prodigy once said "smack my bitch up"
slap that sliiy bolt... and give it one for me too.
Posted on: 2006/8/13 8:46
