« 1 (2) 3 4 5 ... 7 »
Re: Front End of L16 1200
From Geelong, Vic
how do you manage to get it registered with the L16 with out engineers
doesnt it need to be engineered coz its been modified?
i was going to try the old, i needed to change to this engine to run unleaded, the wreckers said it bolted straight in
Posted on: 2006/8/15 10:48
From Adelaide, Australia
That might be the way to go, just act ignorant!
I was talking to Baz at Datsport about it, he said any larger than 1.6 and i would need engineering cert. Gold thing is, do that then use L18 crank rods and pistons and bore to 85mm and have a road reg'd 1.8L 1200!
My mate was putting a E15 motor in his 1000 and he got the all clear from Regency Park just had to go for no. inspection.
Posted on: 2006/8/15 10:57
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Geelong, Vic
so if i built an engine like the one waiting to be bored sitting on my engine stand, and put my dastun 1600 rocker cover one it
ill have to see if any cops can find the engine number on it
Posted on: 2006/8/15 11:06
Yeah you might want the engine plate to atleast say L16 Got a dremel?
Yeah i want a 2.4L roaring under a datsun 1600 rocker cover.
Posted on: 2006/8/15 11:13
IPRA Build
From Geelong, Vic
well the L20b is in there now, ive got the L16 to be bulit with the L18 crank rods and pistons all there
so when that goes in i can look for the crank for the L20b to make it a bit bigger
Posted on: 2006/8/16 7:59
From Sydney , NSW
Hey Whtey,
looking good there!!!!! Shout yourself a can of matt black for under that guard Seriously, looks good - money spent will all be worth it during the first drive !!
Cheers mate
Posted on: 2006/8/16 12:33
Cheers R-fast... i will be doing something with the underside of the car soon, probably get it up on a hoist and go over it with the high pressure cleaner and give it a spray over.
Still waiting for springs, hope i get a call tomorow!
Posted on: 2006/8/16 12:47
IPRA Build
Posted on: 2006/9/12 14:35
IPRA Build
Posted on: 2006/9/12 14:43
IPRA Build
Well its all in, stock stanza radius rods are too long as i thought they may be. Pintara stockies fit like a dream, just have to bleed brakes now.
Posted on: 2006/9/12 16:48
IPRA Build
