Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
wots struts 2 use
RAD_00T
Posted on: 2006/8/17 8:33
hey all need to no wot struts to use on ma 1981 dato 1200 ute so i can put wheels. went to a wheel place to get some tryed on they tryed them on wif spaces but dont fit becuase of ma standard struts so wot struts do i use and wot disc brake set up do i use and is there any mods im volved thanks
#2
Re: wots struts 2 use
Mildman
Posted on: 2006/8/17 8:38
Dude, you'll have to mention what type of wheels you want to put on your car for people to be able to answer your question. e.g 13 x 5.5....12 x 6
#3
campo
Posted on: 2006/8/17 8:49
whats the max size without rolling the guards will fit under 79datto ute with a 120y front conversion. i really like turboutes mags.
wouldnt mind gettin a set. i heard theyre fairly rare tho. how much work is involved in getting 17s under? and what if i put 7 or 6inch rear width and 6.5inch fronts tyres. would that effect steering much or what? cheers
#4
RAD_00T
Posted on: 2006/8/17 8:52
its
size- 15*6.5 hole/pcd -8/100- 114.3 off set - 42
#5
Fat_120y
Posted on: 2006/8/17 12:43
hey campo, 120y struts pump guards an a single spacer an ull get 17's under it, we know through my cousins ute
#6
Re: What struts to use?
Dodgeman
Posted on: 2006/8/17 12:58
If the wheels do not fit the car, then perhaps you need to have another look at what's available in the wheel catalogue, rather than trying to re-engineer your whole front end to fit the wheels.
#7
campo
Posted on: 2006/8/18 6:56
id rather re-engineer
.. cheers fatty. ill do that
#8
RAD_00T
Posted on: 2006/8/18 7:55
dodgeman so wot 15" wheels would fit under wif stanza struts that i am putting on specs
#9
Dodgeman
Posted on: 2006/8/18 9:16
What 15" wheels? I believe that TRX wheels are popular, but I prefer the look of the earlier Skyline wheels as used by both Benny & Rfast on their race cars [at least, I think they are 15"]
If the rims are rubbing on the struts, then they are probably front drive wheels & these very frequently have no 'dish', & as a result, look bloody awfull, in my view. Have a good look at what others are running & see if you can find something you like. There is no need to have new wheels on the car within a week is there? Hasten slowly to get the most satisfactory outcome. You can view topic.
