Browsing this Thread:
1 Anonymous Users
right turn signal doesnt work |
From Vancouver BC Canada
The left does operate but not the right.... gathering thoughts before I operate.
Posted on: 2006/8/18 4:25
Quote: If at first you don't succeed, lower your standards. Keith (Mac-Datty)
Re: right turn signal doesnt work |
From Brisbane Australia
First thing I would do is replace the flasher can, failing that pull of the indicator stalk and clean all the contacts. Also check the bulbs and sockets and if that fails stick your arm out the window. cheers Ade
Posted on: 2006/8/18 9:30
well it worked at least one time today so I am leaning towards the indicator conections...
Posted on: 2006/8/19 3:46
Quite a regular
From Brunswick, Melbourne Australia
Keith, the indicator switck only provides power to a small square box called a relay. The relay is a remotely controlled swich which closes the contacts to switch the power to all the indicaror lights. If all the indicators on one side are crook , it could be the relay, if only one or two indicator lights don't work but one still does then check the bulbs.
Posted on: 2006/8/19 11:01
