Twin Piston Calipers for sale
From Perth
I have 3 sets of sumitomo twin piston calipers.
They are second hand but in good conditon. I am after $150 per set
here is a photo from datrats of what they look like (but not reconditoned like these ones.)
Posted on: 2006/8/24 13:03
Re: Twin Piston Calipers for sale
From Geelong, Vic
are they to suit vented discs like the ones in the pic or are they for solid disc like most standard ones?
Posted on: 2006/8/24 13:05
From Brisbane
What they bolt on too?... stanza?
Posted on: 2006/8/24 13:06
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Geelong, Vic
they bolt onto stanza 200b and 240k struts
if they are to suit solid disc, they go on the stanza struts nicely with 200b discs, the early ones
Posted on: 2006/8/24 13:09
From Perth
They are for solid disks but you only need to make spacers like the ones in the photo if you want vented. They bolt on to most early datsun struts with 90mm bolt pattern.
I use 240k rotors with my setup not sure about 200b rotors but i will check. yes they are the same DBA 315.
Posted on: 2006/8/24 13:35
From Geelong, Vic
yeah me and boofhead are using these calipers with 200b discs
Posted on: 2006/8/24 13:41
don't drag me into this ..... 200b codswallop !!! .... i used 240k slotted rotors
stop great with the setup i've got but i think you're looking for big $$$ for non reco'ed calipers ...
i managed to to buy mine and get them reco'ed for less than your asking price ??
for the 200b rotors i think it's the australian model ?? disc is 253mm diameter and the same part number as the 240k one
Posted on: 2006/8/24 14:02
From Geelong, Vic
oh sorry mr 240k discs, at leastmy calipers have paint on them
Posted on: 2006/8/24 14:04
From Brisbane
looks great boof... I see you used those massive brake lines! Those short stock ones are a bugger when taking struts out
Posted on: 2006/8/24 14:06
teflon lined braided lines made to suit
paint ????? pffffft !! what does paint add to the performance
Posted on: 2006/8/24 14:25
