« 1 (2)
Re: Twin Piston Calipers for sale
From Newscastle, Australia
what vented disc can u use for these on a stanza strut??
Also will they fit under a 13 in rim??
Posted on: 2006/8/24 21:56
Dont die wondering.....
From Perth
I not sure what DATRAT use i thought it was Verada?.
But i have just converted some Suzuki Swift GTI rotors for my new setup. They are 250mm in diameter (close to the 253mm standard) and have 47mm offset (48mm standard) also they are only 18.5mm thick and can be machined down to 16.5mm.
I needed to get the centre hole enlarged and get 4 new bolt holls drilled, but it was very easy conversion. But i am not using these calipers. I am now using willwood dynalites.
Posted on: 2006/8/25 0:06
cant quote me on this but after looking thru a DBA catalog and checking all the dims the disc could be a gazzelle
vented rotor on the stanza hub with a spacer to give it the correct offset ??
Posted on: 2006/8/25 0:47
From Perth
Ok. only 1 pair left i will sell them for $160 including postage. (Postage to the East about $30) Or $120 for local.
Posted on: 2006/9/9 12:26
go the Willwoods,,,I have 4 spot superlites!!!
Posted on: 2006/9/9 23:19
« 1 (2)
