can you go bigger than 32/36 for a A15????
Not too shy to talk
From Sydney
G'day all,
Do you know if you can go bigger than 32/36 webbers on a A15??? ive already ordered them, but now im thinking of bigger, or is the next size up to big???
Cheers
Posted on: 2006/8/31 7:52
Re: can you go bigger than 32/36 for a A15????
Sure you can. Several people are running 40mm bore carbs.
And here's a fun A15:
Weber 32/36
The question is: Do you really want bigger carbs? Does your engine run more than 7000 rpm?
Posted on: 2006/8/31 8:18
From Adelaide, South Australia
Do you mean a 40 dcoe weber ?
That would be the next step from a 32/36 and single 40mm weber and then twin 40mm webers.
Posted on: 2006/8/31 13:25
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Okinawa, Japan
Some people even run 44mm Mikuni/Solexes and 45mm Webers.
Posted on: 2006/8/31 13:39
Cant see the point in going that big with the carbs you cant get the ports that big to flow the air.
Posted on: 2006/8/31 13:45
Albert Einstein
From Townsville, Qld
You meant with downdraft carbies right? because the answer is yes. But you'd definatley want to have a motor that can hold it's own without them due to lack of airflow like bigger motors have in spades.
That just made me think, if the 32\36 came off 4litre Cortina's and they are heaps good on our motors, does that mean that they were asthmatic lumps of crap on the Fords? and what would they have used for upgrades besides sidedrafts?
Posted on: 2006/8/31 15:02
They upgrade 4.2 litre jeeps with the 32/36. It's probably good for at least 150hp. The next step up is a bigger 2-barrel (like a GM rochestor or a traditional Holley).
Posted on: 2006/8/31 17:12
From South Africa
36/36 DCD7 work good. EVERYTIHING in carb can be optimize to suit motor. Or 38/38/DGAS from Ford 3ltv6 work good and is cheaper.
Posted on: 2006/8/31 20:42
From Ipswich, QLD
i'm about to upgrade to 40mm dellorto's FUN FUN FUN
ty
Posted on: 2006/9/1 9:11
