#1 Are intercoolers needed?
Turboron Posted on: 2006/9/1 14:47
OK, I'm just getting started looking into turbo's and was wondering if intercoolers were needed. They're supposed to cool the air, producing a more condensed fuel air mixture, right? So why doesn't everyone have them? Especially in the hot area's such as where I live?
Thanks
#2 Re: Are intercoolers needed?
killer1200 Posted on: 2006/9/1 15:34
They dont do anything to the Fuel just the air.
Its just young kids that get them to be cool, but they do stop detonation and give you more HP.(Ok its not only people that are trying to be cool)
I think your better off to go with water injection.
#3 Re: Are intercoolers needed?
Daveman Posted on: 2006/9/1 15:48
Believe it or not, intercoolers to have a practical purpose! They reduce the temperature of the compressed air, like you said they increase air density and therefore increase HP. The reason EVERYBODY doesn't have them is that they cost money and their benefits are directly proportional to the level of developement of your turbo system. Very basic, low boost turbo applications don't show big improvements from intercooling but the more serious it gets the larger the advantages of running an intercooler become.
#4 Re: Are intercoolers needed?
ddgonzal Posted on: 2006/9/1 16:44
NO. The original Porsche Turbo did not have one.
#5 Re: Are intercoolers needed?
dattodude Posted on: 2006/9/1 16:47
In Arizona...having a turbo without intercooler is a crazy idea. Any place with temperatures over 80degF (30degC) really see the benefit of intercoolers.
If you are happy to run less than 6psi..then you can run without one.. but you will not be impressed by the power output of the engine.
#6 Re: Are intercoolers needed?
B210sleeper Posted on: 2006/9/1 17:49
lots of oem low boost turbos have no or very little intercooler.
All that happens is you get less power by not having one since the computer will retard the engine when you get up to detonation, which will happen at a lower power level than with an IC. use an IC with water/methanol injection or LPG and N20 ( if you're crazy ) the idea is to get rid of the heat that the compressor added.
since nobody said it yet ;)
don't IC a suck through ;) it should be obvious why... i just have to someone always post about not doing this...
some IC's use water and have a mini radiator somewhere else, this has some advantages...
#7 Re: Are intercoolers needed?
Dodgeman Posted on: 2006/9/2 0:13
And of course, suck through turbo systems generally do not use them as they can play havoc with the mixture, ... along with other problems.
#8 Re: Are intercoolers needed?
dattodude Posted on: 2006/9/2 0:24
In a 'suck through' system the fuel will hit the cool surfaces of the intercooler causing problems with atomisation. The first intake backfire and "boom" the front of your car goes missing.
#9 Re: Are intercoolers needed?
Dodgeman Posted on: 2006/9/2 0:33
Hence the 'other problems' comment with tongue very firmly planted in cheek.
The fuel condensing inside the intercooler causes a lean mixture which is very prone to induction backfires.
#10 Re: Are intercoolers needed?
ddgonzal Posted on: 2006/9/2 0:49
less than 6psi...you will not be impressed by the power output of the engine.
I recall several members of our club were excited at the power incresase when they ran less than 6psi boost ...
To recap: No, you don't need an intercooler. But they are worth it. You can make "big" power with them and only "increased" power without one.
