Re: Fuel Problems
From SE Melbourne
The simplest answer is to put it back the way it was.....if that works - then it must be something you've done....then it will be a process of elimination.
Pop the fuel hose of the carby, pull the IGN lead of the coil - crank the motor - see if fuel comes out of the hose (into a jar you hold over that hose).
If that works then you should be good - if it doesn't if either fuel filter wrong way round? or fuel pump in trouble.
It's all in the workshop manual (the fuel system diagnosis) by the way.
Posted on: 2006/9/3 8:08
Mildman, Datsunless
Subject Poster Date
     Fuel Problems d1t 2006/9/3 6:43
       Re: Fuel Problems A14force 2006/9/3 6:52
         Re: Fuel Problems d1t 2006/9/3 7:41
           Re: Fuel Problems Mildman 2006/9/3 8:08
             Re: Fuel Problems d1t 2006/9/3 9:27
