Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
WTD auto ute tailshaft
PIGDOG
Posted on: 2006/8/27 13:51
looking for an auto ute tailshaft for my L series conversion
would profer if it was in victoria but if it is cheap enough ill be happy to pay postage from other states name prices
#2
Re: WTD auto ute tailshaft
Dodgeman
Posted on: 2006/8/27 14:01
As far as I can tell, there never was a Datsun 1200 ute with auto trans, so finding a driveshaft will be difficult.
I think you will need to find a one piece driveshaft from L series powered model that used an H165 rear end. The wagon models of the 1600, 180B would be candidates, & I suspect that the later model, facelifted, 200B's with the Warner box & diff still use the same slip yoke & pinion flange pattern, so the choices are there. All of the first generation of 200B [pre facelift] with the live rear axle used a two piece driveshaft. Naturally you will need to have it shortened to the right length to make it work. I don't know if the later 910 Bluebirds used a one piece driveshaft or two piece but they are worth a look.
#3
PIGDOG
Posted on: 2006/8/27 14:11
son of a....
ok which L series tail shaft has the biggest unis, ill get that one shortened stupid bluebird one is about 1.5 inches too long to fit with the ute diff
#5
PIGDOG
Posted on: 2006/9/6 4:53
nah, it will be an inch longer than what i need, decided just to find an L series with huge unis and cut that tailshaft down to suit
was going to try to get one for the H150 i have, but then i got the ute diff so i need custom
#6
heathbruce
Posted on: 2006/9/6 5:00
I got Jeff Lagerwey Tailshafts in Ferntree gully (9758-4015) to cut mine down. He charged about $150 from memory which included 2 new unis.
#7
1200rallycar
Posted on: 2006/9/6 5:02
what about a coupe auto shaft? where did you come up with this needing a ute auto one?
i second the guy in fern tree gully, had 3 or 4 done by him, all perfect
#8
gx1200
Posted on: 2006/9/6 6:57
Try a 180b sedan tail shaft, depending on how your L series is mounted you may not even need to chop it. I had a ute diff in my two door with the CA and a gazelle box, the 180B shaft bolted straight in. Cheers. Adam.
#9
ANGE
Posted on: 2006/9/6 7:36
universal driveshafts in north melbourne is also very good..
stay away from M&S driveshafts in sunshine.. i have delt with them and wouldnt let them work on my wheelbarrow, let alone my datto i have a cut down auto stanza tailshaft in my ute...
#10
PIGDOG
Posted on: 2006/9/6 13:41
auto ute (if they were made) would have been perfect as auto 1200 ones work nicely with where most L series sit, as im using a ute diff i would have needed an auto tail shaft that would have suited the length of what a ute auto tailshaft would have been
ive tried a 180b one, it was too short tried a bluebird one, about 1.5 inches too long have yet to find a stanza one to try, might be right but after being stranded arfter my brothers corolla killed one of the unis, i thought id try to go for something that had nicely size unis You can view topic.
