(1) 2 3 »
WTD auto ute tailshaft
From Geelong, Vic
looking for an auto ute tailshaft for my L series conversion
would profer if it was in victoria but if it is cheap enough ill be happy to pay postage from other states
name prices
Posted on: 2006/8/27 13:51
Re: WTD auto ute tailshaft
As far as I can tell, there never was a Datsun 1200 ute with auto trans, so finding a driveshaft will be difficult.
I think you will need to find a one piece driveshaft from L series powered model that used an H165 rear end.
The wagon models of the 1600, 180B would be candidates, & I suspect that the later model, facelifted, 200B's with the Warner box & diff still use the same slip yoke & pinion flange pattern, so the choices are there.
All of the first generation of 200B [pre facelift] with the live rear axle used a two piece driveshaft.
Naturally you will need to have it shortened to the right length to make it work. I don't know if the later 910 Bluebirds used a one piece driveshaft or two piece but they are worth a look.
Posted on: 2006/8/27 14:01
Love your Datsun.
Treat it well.
From Geelong, Vic
son of a....
ok which L series tail shaft has the biggest unis, ill get that one shortened
stupid bluebird one is about 1.5 inches too long to fit with the ute diff
Posted on: 2006/8/27 14:11
From Adelaide, Australia
Dude will a H150 tailshaft work?
Posted on: 2006/9/5 14:33
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Geelong, Vic
nah, it will be an inch longer than what i need, decided just to find an L series with huge unis and cut that tailshaft down to suit
was going to try to get one for the H150 i have, but then i got the ute diff so i need custom
Posted on: 2006/9/6 4:53
From Melbourne, Aus
I got Jeff Lagerwey Tailshafts in Ferntree gully (9758-4015) to cut mine down. He charged about $150 from memory which included 2 new unis.
Posted on: 2006/9/6 5:00
From Melbourne, Australia
what about a coupe auto shaft? where did you come up with this needing a ute auto one?
i second the guy in fern tree gully, had 3 or 4 done by him, all perfect
Posted on: 2006/9/6 5:02
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Adelaide. SA
Try a 180b sedan tail shaft, depending on how your L series is mounted you may not even need to chop it. I had a ute diff in my two door with the CA and a gazelle box, the 180B shaft bolted straight in. Cheers. Adam.
Posted on: 2006/9/6 6:57
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From Melbourne AUS
universal driveshafts in north melbourne is also very good..
stay away from M&S driveshafts in sunshine..
i have delt with them and wouldnt let them work on my wheelbarrow, let alone my datto
i have a cut down auto stanza tailshaft in my ute...
Posted on: 2006/9/6 7:36
1973 B110 A12
From Geelong, Vic
auto ute (if they were made) would have been perfect as auto 1200 ones work nicely with where most L series sit, as im using a ute diff i would have needed an auto tail shaft that would have suited the length of what a ute auto tailshaft would have been
ive tried a 180b one, it was too short
tried a bluebird one, about 1.5 inches too long
have yet to find a stanza one to try, might be right
but after being stranded arfter my brothers corolla killed one of the unis, i thought id try to go for something that had nicely size unis
Posted on: 2006/9/6 13:41
(1) 2 3 »
