ute leafs vs. coupe leafs
From Melbourne, Australia
the ute leafs seem too hard and mean a lot less traction
i'd like to put my old coupe springs in,
is the coupe main spring identical length/ mounting or do i need to swap the main spring?
Posted on: 2006/9/6 7:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: ute leafs vs. coupe leafs
From Melbourne AUS
not sure if they fit... but you will probably get more tramp wont you with coupe springs?
Posted on: 2006/9/6 7:38
1973 B110 A12
From Brisbane
should be identical, i have had my mates old ute springs in my coupe a while ago
Posted on: 2006/9/6 7:40
i didnt no ther was a difference
From Melbourne AUS
the utes have a 4 leaf rear as standard
Posted on: 2006/9/6 8:03
1973 B110 A12
then how many do the coupes have
Posted on: 2006/9/6 8:08
From Brisbane
the main spring is identical
Posted on: 2006/9/6 8:14
From Central Vic
This is a good swap to do it nice disassemble the coupe and ute springs and fit the ute over-rider to the coupe spring set this means that should you put some weight in it will at least have some chance and the U bolts will be the right length
Adds mid corner traction but if your shocks and bushes aren
Posted on: 2006/9/6 8:50
to buy or not to buy???? OK
This is the reason I have five coupes
