Re: Gear stick bushes??
From Adelaide, SA the drift state
pics of all these setups
Posted on: 2006/9/6 13:03
From Adelaide, Australia
Does anyone know if z car ones will fit because they often have these in different materials on ebay.
Posted on: 2006/9/6 13:25
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Nah, the Zed car uses a bigger box & even the pivot pin through the gear lever is bigger, so the bushes are bigger too.
Just see your friendly Nissan Dealers parts department.
Posted on: 2006/9/6 13:30
Love your Datsun.
Treat it well.
Cheers, would the 63a box be the same as the Z?
Posted on: 2006/9/6 13:32
IPRA Build
As far as the bushes go, it just might be the same, but depending on the Zed car model as to what gearbox it used. I think that some of the early ones might have used the 63 series box.
Posted on: 2006/9/6 13:42
Love your Datsun.
Treat it well.
Might do some research at the wreckers when i get time.
Posted on: 2006/9/6 13:50
IPRA Build
From Perth
32855-H1010
Posted on: 2006/9/6 14:32
From SE Melbourne
You know after pulling out 4 gearsticks from 1200's 120Y's Sunny's I haven't found one yet that actually had those bushes in it....it's like they've all worn away to nothing.
Posted on: 2006/9/6 14:45
Mildman, Datsunless
From Canberra
well I'm using a s2 bluey shifter in my FJ box, and mr30 shifters fit too, mr30 had a L24 so is most probably the same as Z box.
Posted on: 2006/9/7 0:01
From Canberra. ACT
I had 2 new ones machined from brass for me by a friend that was a long time agao and I have had no problems there since
Posted on: 2006/9/7 2:45
« 1 (2) 3 »
