« 1 (2)
#11 Re: Twin Piston Calipers for sale
converted Posted on: 2006/8/24 21:56
what vented disc can u use for these on a stanza strut??
Also will they fit under a 13 in rim??
#12 Re: Twin Piston Calipers for sale
rally1200 Posted on: 2006/8/25 0:06
I not sure what DATRAT use i thought it was Verada?.
But i have just converted some Suzuki Swift GTI rotors for my new setup. They are 250mm in diameter (close to the 253mm standard) and have 47mm offset (48mm standard) also they are only 18.5mm thick and can be machined down to 16.5mm.
I needed to get the centre hole enlarged and get 4 new bolt holls drilled, but it was very easy conversion. But i am not using these calipers. I am now using willwood dynalites.
#13 Re: Twin Piston Calipers for sale
boofhead Posted on: 2006/8/25 0:47
cant quote me on this but after looking thru a DBA catalog and checking all the dims the disc could be a gazzelle
vented rotor on the stanza hub with a spacer to give it the correct offset ??
#14 Re: Twin Piston Calipers for sale
rally1200 Posted on: 2006/9/9 12:26
Ok. only 1 pair left i will sell them for $160 including postage. (Postage to the East about $30) Or $120 for local.
#15 Re: Twin Piston Calipers for sale
converted Posted on: 2006/9/9 23:19
go the Willwoods,,,I have 4 spot superlites!!!
« 1 (2)
