Re: rear disc brake conversion
From Sydney , NSW
Yes Series 2 910 discs will fit. You can use them with your H145 axle housing also. Remove the bearing retainer and bearing from both H145 and H165 axles, swap disc brake backing plates onto your H145 axles and install new bearings and retainers. Check for a spacer on the H145(I think) which is to be reused. I had done this with my H145 - a bit of a hassle but can be done without too much drama if you are mechanically inclined. Bleed nipple may interfere with chassis rail on hard corners so you may have to scallop at that point. Anyway, keep searching on this site as more detail is likely to be found
Cheers
Posted on: 2006/9/10 2:58
Subject Poster Date
     rear disc brake conversion Turboron 2006/9/8 22:57
       Re: rear disc brake conversion evilsim 2006/9/9 0:56
         Re: rear disc brake conversion R-fastmotorsport 2006/9/10 2:58
