#1 changing diff oil?
frankthedolphintrainer Posted on: 2006/9/7 3:37
just wondering if you need a special tool or somthing to remove the drain plug it looks like it need some type of square shaped allen key.
#2 Re: changing diff oil?
heathbruce Posted on: 2006/9/7 3:43
try the half inch drive on your ratchet
#3 Re: changing diff oil?
sunny_coupe110 Posted on: 2006/9/7 3:47
Spiner Hendel or BOX wrench is handled.
12.7mm
Let's try.
#4 Re: changing diff oil?
dooffy Posted on: 2006/9/7 4:03
i just checked my diff oil level in my 620 & all i used was 1/2 inch ratchet fitted straight in try it
#5 Re: changing diff oil?
frankthedolphintrainer Posted on: 2006/9/12 3:05
thanks for the tip guys
#6 Re: changing diff oil?
Duncan Posted on: 2006/9/12 4:43
Getting the fluid out is the easy part. Refilling it is the tricky part, unless you have some sort of pump.
#7 Re: changing diff oil?
ang94541 Posted on: 2006/9/12 6:48
Blood transfusion I hope this helps getting the oil back in.
#8 Re: changing diff oil?
Mildman Posted on: 2006/9/20 0:50
I did it this way recently (with the use of a compressor) - although I think the compressor is still a pretty good idea.
#9 Re: changing diff oil?
Turboron Posted on: 2006/9/25 18:40
The pressurized jar is a sweet idea! Never even thought of that. I'm going to make one this weekend. BTW, I have a CokaCola type shelf myself. Sometimes dumpster diving turns up some rare jewels!!
#10 Re: changing diff oil?
B210sleeper Posted on: 2006/9/25 19:31
if you can't get the drain plug out ( someone wrenched mine in ) you can siphon the oil out over night and then replace it. ( not quite as good as a real drain, but when you can't get the plug out it's better than nothing. )
