« 1 2 3 4 (5) 6 7 8 ... 12 »
#41 Re: strut bars - e.o.i
WhiteSedan Posted on: 2006/9/12 12:23
Hey Boof, what size are the bolt holes? They look quite large, are they for stanza M10 or 1200 M8?
#42 Re: strut bars - e.o.i
boofhead Posted on: 2006/9/12 12:27
the holes are 12mm, i looked at going smaller to suit the m10 bolts but wasn't convinced on them lining up nice and simply. They sit nice over my camber tops and over the stanza tops, not loose at all.
edit : the centre hole is 100.5mm and fits nicely over the lipped section to locate the top spot on.
#43 Re: strut bars - e.o.i
Mildman Posted on: 2006/9/12 12:40
I'm off work next week - so up for a mini meet during the week or on the weekend!
These struts braces indeed look cool, Mik convinced me to get some camber tops as well. That and adjustable LCAs should look the goods on the track.
Might be talking adj height platforms soon too....thanks again Boof - I hope you getting something out of all this ingenuity and generousity.
#44 Re: strut bars - e.o.i
WhiteSedan Posted on: 2006/9/12 12:40
Cool, I may have to make up some small bushes because my noltec strut tops are m8 like a 1200, might look into it tomorow.
#45 Re: strut bars - e.o.i
boofhead Posted on: 2006/9/12 12:43
you should find it'll locate spot on with the centre hole, stainless washers shouldn't collapse into the bolt holes ??
#46 Re: strut bars - e.o.i
hcope86 Posted on: 2006/9/12 12:43
If there are any spots left PLZ put me down for one, im hella keen!
Cheers
#47 Re: strut bars - e.o.i
boofhead Posted on: 2006/9/12 12:46
you've been added to the 2nd batch ... it was originally going to 10 only but could stretch to 20 if there is enough interest ??!!!
#48 Re: strut bars - e.o.i
Posted on: 2006/9/12 12:47
yes ben, wil go very nice in the front end wont they, tops, bars, springs, sway bars brakes....
now if we could all find h165's and get the rear ends sorted and an endless supply of cheap and relianbe 60a 5 speeds we could al be very happy datto owners
#49 Re: strut bars - e.o.i
Mildman Posted on: 2006/9/12 12:52
by unfamilia on 2006/9/12 22:47:39
Of course you meant H165 LSD diffs...hmmm 60a 5 speeds, speaking of which I didn't end up having a good look the other day for gearboxes....might start a new thread.
#50 Re: strut bars - e.o.i
Curtis Posted on: 2006/9/12 13:01
Anyone in the first batch be able to check if it will fit a 120y (just sit it on top of strut bolts/nuts) If there is and they fit then u can put be down for one of the second batch boof, if any spots left that is.
