Wanted Alloy H165 centre, but found Alloy H190 centre...
Went looking at a wreckers for a Alloy H165 diff, I couldnt find one but as I walked out there was an old Datsun1500 ute, stuck my head under the back, gave the diff centre a scrape, and to my surprise it was an Alloy housing... BINGO!!
Not really what I was looking for but thought I would grab it as they are hard to find...
Posted on: 2006/9/12 7:28
Re: Wanted Alloy H165 centre, but found Alloy H190 centre...
From Tamworth, NSW
Good stuff. Pays to know your stuff !! For your interest i dont have much of a idea
Posted on: 2006/9/12 10:14
Project coupe:
Just drive it
From Central Vic
your looking for a early should i say the first bluebird
the bent bannana bluebird, 60's bluebird, twin head light
they look a bit like a morris
theses have alloy centers but rember they are impirial threaded at that stage
Posted on: 2006/9/13 2:18
to buy or not to buy???? OK
This is the reason I have five coupes
From Melbourne, Australia
wanna sell?, what ratio?
pm me if intrested in selling
Posted on: 2006/9/13 2:50
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Sorry dont really want to sell it, I might end up needing to use it in my 1000...
Sorry...
Posted on: 2006/9/13 2:53
keep me in mind if you do ever decide to get rid of it
still curious on the ratio anyway, hope that wasnt at centre road, i could have beat ya to it if i had more time when i was there on satdy
Posted on: 2006/9/13 7:18
1200 Coupe Rallycar
From Mudgee NSW Australia
Topgear that is the exact diff I run in my ca18det 1200 the width is spot on (around 20mm wider than stock) they run 29spline axles and are 4.625:1 ratio. The 720 series datsuns and early navara centers fit giving you a choice of 4.11 4.3 4.625 4.825 and 5.1 only the 4.6 is alloy and unfortunately the crownwheel and pinions are not interchagable. If you happen to make a LSD to suit this I would be more than happy to purchase one.
Cheers Andrew
Posted on: 2006/9/13 11:00
If In doubt run more BOOST
I am making H190 lsd's at the moment... Would have thought that they would fit but I could be wrong???
Posted on: 2006/9/13 12:47
The diffs will fit the only probelm will be if they have the center rubbing block for the axles to locate. The axle flange is shimed to give the tapered bearing preload you will figure this out once its all appart. If the centers your are building will work let me know.
Cheers Andrew
Posted on: 2006/9/13 14:06
