Burnt Points ?
Quite a regular
From South-Africa Pretoria
Hi,maybe one of you could help me. Every time
I put in new points it last only a week or two
and then it is burnt! What could be the reason? Is it the resistor or the gap of the points?
Groete CCG
Posted on: 2006/9/13 20:05
Re: Burnt Points ?
Replace both the points AND the condenser with new parts.
Posted on: 2006/9/13 21:45
Love your Datsun.
Treat it well.
Re: Burnt Points ?
From Burbank, CA
isn't there supposed to be a resistor to keep the points from burning?
Posted on: 2006/9/14 0:45
|||\ 81 KPB310 /|||
Re: Burnt Points ?
From Bunbury Western Australia
yeah the ballast resistor is to drop the voltage down when the engine has started, if he is not using a ballast resistor and just using straight 12V to the coil then that would also wear the points pre-maturely
Posted on: 2006/9/14 2:49
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: Burnt Points ?
Quite a regular
I took a reading of the resistor,its about 1.8ohm. Is it ok? What should the voltage be on the coil? My coils voltage is about 4 - 5V.
Thanx 4 the advice!
Groete Ccg
Posted on: 2006/9/17 22:59
