Re: bluebird rear end into 120y?
From Geelong, Vic
2 wheel drive 720 h190 diff is the same width as bluebird h165
if your only wanting the diff to handle an L20b, y not just use a 1200 ute diff?
only have to cut the spring mounts off the 120y diff and weld them onto the ute diff and it will go straight in
Posted on: 2006/9/18 6:38
Subject Poster Date
     bluebird rear end into 120y? tom210 2006/9/13 15:34
       Re: bluebird rear end into 120y? blofly 2006/9/13 15:59
         Re: bluebird rear end into 120y? Cable_Tie 2006/9/13 22:53
           Re: bluebird rear end into 120y? blofly 2006/9/14 3:02
             Re: bluebird rear end into 120y? Tyrie 2006/9/14 4:40
               Re: bluebird rear end into 120y? tom210 2006/9/14 4:49
                 Re: bluebird rear end into 120y? Tyrie 2006/9/14 4:52
                   Re: bluebird rear end into 120y? tom210 2006/9/14 5:00
                     Re: bluebird rear end into 120y? L18_B110 2006/9/14 6:40
                       Re: bluebird rear end into 120y? tom210 2006/9/14 7:14
                         Re: bluebird rear end into 120y? BigV 2006/9/15 5:41
                           Re: bluebird rear end into 120y? Tyrie 2006/9/15 7:59
                             Re: bluebird rear end into 120y? tom210 2006/9/15 13:09
                               Re: bluebird rear end into 120y? BigV 2006/9/16 1:49
                             Re: bluebird rear end into 120y? pro-240c 2006/9/18 1:29
                               Re: bluebird rear end into 120y? tom210 2006/9/18 3:17
                                 Re: bluebird rear end into 120y? PIGDOG 2006/9/18 6:38
                                   Re: bluebird rear end into 120y? pro-240c 2006/9/18 12:46
                                     Re: bluebird rear end into 120y? dog160 2006/9/18 12:54
                                   Re: bluebird rear end into 120y? L18_B110 2006/9/19 2:00
                                     Re: bluebird rear end into 120y? PIGDOG 2006/9/19 12:23
                                       Re: bluebird rear end into 120y? tom210 2006/9/19 13:56
                                         Re: bluebird rear end into 120y? WhiteSedan 2006/9/19 13:58
