« 1 (2) 3 4 »
#11 Re: COIL-OVER KITS
sssute Posted on: 2006/9/17 14:03
Laney, they will fit your struts no worries, depending on what strut tops you are using,you may have to drill the spring top hat slightly. (very simple process)
Scott
#12 Re: COIL-OVER KITS
dattodude Posted on: 2006/9/17 14:28
Ok, so for the price I'd get:
1. 2x threaded part to be welded to strut.
2. 2x spring holder top/bottom and lock ring.
3. 2x adjusting spanner (got to lock them)
I can get the springs made locally.
But I'd be looking to get as much of the other bits as possible. Time is my biggest enemy.
Can you quote the delivery to my sydney address via PM or email?
I'm running the 180B struts which have the "larger than 1200" strut tubes. I'd guess they'd be same as stanza.
Regards,
Chris
EDIT: This is correct on what the deal includes.
#13 Re: COIL-OVER KITS
Laney Posted on: 2006/9/18 12:20
hey champ yeh ill get a set im runnin camber tops will this make any difference? and how much r springs?
cheers budy
#14 Re: COIL-OVER KITS
sssute Posted on: 2006/9/18 13:45
Dattodude.
I PMed You.
#15 Re: COIL-OVER KITS
dattodude Posted on: 2006/9/18 13:46
I've already paid
#16 Re: COIL-OVER KITS
sssute Posted on: 2006/9/18 13:51
Laney, Let me know what the inside diameter of the pillow ball that your tops have, as i do have a componet that i use for my tops. Sorry i dont supply springs, but you can get them from a lot of suspention shops. They suit 65mm springs.
Scott
#17 Re: COIL-OVER KITS
sssute Posted on: 2006/9/18 13:56
Thank Chris
#18 Re: COIL-OVER KITS
b110coupe Posted on: 2006/9/18 14:10
Put me down for a set :)
How long will the threaded sleeves be? as in how much height adjustment are we talking?
any pics?
#19 Re: COIL-OVER KITS
Daveman Posted on: 2006/9/18 15:13
PM sent
#20 Re: COIL-OVER KITS
sssute Posted on: 2006/9/19 8:36
b110coupe, the sleeves are 100mm long, which will give you enough adjustment. I'll get some pics on tonight, i have some in my photo album too.
Scott
« 1 (2) 3 4 »
