Re: bluebird rear end into 120y?
From Central Vic
before you go paying to have a diff shortened run a tape measure over a 720 diff at the mounts
althought these are six stud they are much shorter then bluebird diff and as a bonus they are 4.11:1 or lower in the ratio
they have the big axels the same as the blue bird
Posted on: 2006/9/15 5:41
to buy or not to buy???? OK
This is the reason I have five coupes
From Canberra
I just went and measured this for ya, from outside edge of spring mount to outside edge of spring mount is 102cm. From wheel mounting face to wheel mounting face is approx. 145cm (was hard to measure so is only an approximation)
Posted on: 2006/9/15 7:59
From Springwood NSW, Formerly Tas.
can you change the axles over to retain the 4 stud?
Posted on: 2006/9/15 13:09
1978 120y Coupe.
From Central Vic
in the H165 lsd post there is mention of the datsun 1500 ute being shorter agin
ive only ever seen redrilled axels
Posted on: 2006/9/16 1:49
From WA
can someone measure a 120Y diff for a direct comparison?
Posted on: 2006/9/18 1:29
yeah i'll head out in a min..
Posted on: 2006/9/18 3:17
1978 120y Coupe.
From Geelong, Vic
2 wheel drive 720 h190 diff is the same width as bluebird h165
if your only wanting the diff to handle an L20b, y not just use a 1200 ute diff?
only have to cut the spring mounts off the 120y diff and weld them onto the ute diff and it will go straight in
Posted on: 2006/9/18 6:38
From WA
i had my head under a 1980 hiace van today (dont ask why...) and they look VERY close to a 120Y width...
but looks can be deceiving
Posted on: 2006/9/18 12:46
From In front, and pulling away.Sometimes around Sydney....ish!
Tom, PM R-fastmotorsport. He runs a H165 diff with the Series 2 bluebird discs. His race spec L20 hasn't bothered it yet. He does run 13's, but needed a mm or 2 machined off wheels, and a bit of filling on the caliper.
Posted on: 2006/9/18 12:54
Lifes good when your on BOOST!
From Brisbane, Australia
I'll say it again... you could get 3 120Y BW diffs for the same money as 1 ute diff, and they will bolt straight in and handle all the power you'll ever get out of a L20. and if you want to match the track of the front with the 200B struts, the Corolla version of the same BW diff is the perfect width, and it still bolts onto the 120Y leaves.
but if you want to waste money and make it harder for yourself, go right ahead...
Posted on: 2006/9/19 2:00
« 1 (2) 3 »
