poly suspension bushes
From Gold Coast, Australia
hey guys just priced up some urethaine bushes for 1200 ute through autobarn -
Front
control arms - $36
steering idler bushes - $12
strut - chassis - $30
sway bar bushes - $19
Rears
Shock bush - 32 for two sets
spring eye front - $32
Spring eye rear - $23
spring chackle?? - $24
about 200 all up
Didnt ask about brand - just for my street car
Posted on: 2006/9/19 7:22
Re: poly suspension bushes
From Bunbury Western Australia
bloody great value aint it! when I did my VR commodore with a full nolathane kit from to to bottom including camber kits it came to about $2200 I have been lazy with the datto though as I still have the nolathane/noltec kit in the boot of the sedan
Posted on: 2006/9/19 10:28
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Toowoomba Q Australia
So did you also price other retailers like Repco& Super cheap. ?
I've found huge price variations from one retailer to the next
Posted on: 2006/9/19 11:07
Don't you just love the way Datsuns Save. They save you money in so many ways & this just looks like being another.
My 1200 coupe rode more harshly than I thought it should, so I replaced all the rubber suspension bushes with well lubricated urethane ones, as well as fitting a new set of rear spring interleaf friction pads.
The ride quality is MUCH better now & I would describe it as being 'quite firm, but much smoother'
Posted on: 2006/9/19 12:46
Love your Datsun.
Treat it well.
From Melbourne AUS
nice work... i need some idler bushes..
just noticed some movement in there yesterday...
i better start saving
Posted on: 2006/9/19 12:51
1973 B110 A12
its the last components that i got for my suspension cause i have replaced everything with new stuff so my suspension is brand new. new shocks, spring, sway bar, bushes bearings all round, Rebuilt calipers all round, new discs, new pads etc etc. once you start you cant stop because you cant justify leaving one part old when everything else is brand new.
Posted on: 2006/9/19 14:34
From Brisbane
i have just done this to my 1200 coupe on the weekend, with complete poly in the rear end, cost me $89 for all the bushes, only thing is, i had to order 2 extra sets of rear back shackle bushes and drill them out to fit the rear front shackle as no one sells them.
Posted on: 2006/9/20 13:25
From Adelaide, Australia
Something ive heard is to use the poly spring eye bushings but alloy shackle bushings to stop sideways movement when cornering, im going to be doing this with my sedan.
Posted on: 2006/9/20 13:28
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Hmmmm, metal to metal in a load area with moving pins.
Let us know how you go with noise, wear rate, & lubrication difficulties when using aluminium for shackle bushes.
Posted on: 2006/9/20 21:57
Love your Datsun.
Treat it well.
There is only movement in the front shackle bushing. The rears do not have moving pins. I dont care about noise, wear rate or lubrication, my car will be registered but will be aimed at competition use. Same could be said for my strut tops, no lube on a spherical bearing, also looking at alloy bushings for radius rods.
Posted on: 2006/9/21 10:07
IPRA Build
