Re: 1000 Dif
The differential from a passenger model 1200 will fit directly into the Datsun 1000 rear axle housing as both are H145's.
The ratio of the 1200 diff is 3.9 to 1 while your Coupe's original ratio is 4.11 to 1
The rear axle assembly from a 1200 is about 2-1/2" [65mm] wider than the 1000 & this is enough to mess with wheel & tyre clearance in a small car like our 1000's, so this is not really an option in most cases.
Posted on: 2006/9/21 23:29
Love your Datsun.
Treat it well.
Subject Poster Date
     1000 Dif ddienes 2006/9/20 23:14
       Re: 1000 Dif Dundee1000 2006/9/21 3:28
         Re: 1000 Dif ddienes 2006/9/21 23:11
           Re: 1000 Dif Dodgeman 2006/9/21 23:29
             Re: 1000 Dif gx1200 2006/9/21 23:42
               Re: 1000 Dif Dodgeman 2006/9/22 1:12
                 Re: 1000 Dif 1000collector 2006/9/24 8:24
       Re: 1000 Dif ddienes 2006/9/24 23:32
         Re: 1000 Dif ddgonzal 2006/9/25 3:05
