flywheel
From Sydney
whats the best flywheel to use on the a15 i built for my dat 1200 ute with the original box.
i noticed the a15 is thicker than the a12 flywheel.
Posted on: 2006/9/20 6:18
Re: flywheel
From Canberra
most people use the a12 flywheel as its lighter. It should be a straight bolt-up.
Posted on: 2006/9/20 8:54
Re: flywheel
From Brisbane Australia
hi mate I have one in brissy if you get stuck
ade
Posted on: 2006/9/20 9:37
Re: flywheel
From SE Melbourne
I understand the throwout bearing (I think it's calle d that) is different between the A15 and A12 - there's a thread on it somewhere deep in Datto1200.com history......
Posted on: 2006/9/20 14:02
Mildman, Datsunless
Re: flywheel
From Canberra, Australia
I put the 1200 one on mine.
Never had a problem.
After I changed the clutch a few years later, I also got the A12 one lightened.
If you have the money to be able to do this. Then I highly reccomend getting it lightened. Makes the car so much more zippy.
Posted on: 2006/9/22 2:48
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: flywheel
From SE Melbourne
I found where the throwout bearing info is....funny enough it is in the Tech Section in the article describing how to fit an A14/A15 to a 1200.
Probably worth reading that if your interested
Posted on: 2006/9/22 4:44
Mildman, Datsunless
