Browsing this Thread:
1 Anonymous Users
Re: maddat vs datrat BRAKES |
From Adelaide, SA the drift state
so if i use the r31 struts then i dont need a brake upgrade for my ca converison, i am going to use sssute coilover kit which he uses on his r31 struts
Posted on: 2006/9/25 12:10
From Adelaide, Australia
Yeah just get some nice pads to suit the R31 and maybe some better discs, plenty enough brakes.
Yeah ask sssute about the ring spacer on the steering arms. I wish i used his coilover kit not that its better, just about $100 cheaper than the koni one i used and its south aussie made!
Posted on: 2006/9/25 12:13
cheap + fast = disaster fast + reliable = expensive cheap + reliable = stock IPRA Build
were do i get the disks form. i am going to city dosmantlers tomoz to get the struts. so r31 the go plus is there any type of r31 strut i should use
Posted on: 2006/9/25 12:28
I would get a few tools and go to u-pullit man, if you go to city dismantlers and ask for R31 struts your gonna get ripped off hard. Speak to sssute and ask what he's got first. They are the square pintara looking things but are RWD.
I paid $60 for my 280zx struts at u-pullit, grab everything struts/discs/calipers the whole lot. As for discs, go to a brake place like ABS and ask for some slotted discs to suit.
Posted on: 2006/9/25 12:35
wat tools would u need and wat to look out for as in damage way
were is u pull it
Posted on: 2006/9/25 12:44
How much time you got tomorow, i dont start work til 4pm, i'd come help and got tools.
Otherwise its a 17mm for the bottom of the strut, 17mm at the strut tower. Side cutters for the brake line. Have you got the stanza/sunny arms etc?
Damage is just visual really, normally look at the car itself to see how its been looked after. U-pull it is either lonsdale (south) or elizabeth (north), where are you?
Posted on: 2006/9/25 12:51
From Geelong, Vic
with r31 struts you must run adjustable strut tops to maintain any negative camber
Posted on: 2006/9/25 12:59
I'd ask sssute what he's done, you can get them cold bent for more neg, but if its an issue do the research first.
Posted on: 2006/9/25 13:03
im in norwood but travel is fine. well basically tomoz i am free from 1030 till 3. well both u pull its are the same distance. i dont have stanza/sunny arms. gettin them from cty dismantlers is abvout 50 bucks more but easier for me.
Posted on: 2006/9/25 13:04
Get the stuff from the same people then man, pay less that way, I just like to do things myself so i can learn, u-pullit is great that way. What excactly are you getting from city dism? how much will it cost there?
Posted on: 2006/9/25 13:08
