Browsing this Thread:
1 Anonymous Users
Finally, the beast has been tuned!! |
From In front, and pulling away.Sometimes around Sydney....ish!
Finally after much heart ache, the Sunny made it to the dyno. At the end of the day, ( well, 8 runs anyway.) we ended up with a figure of 121.3 rwhp (90.4 rwkw). Not too bad out of a standard A14. It made good torque, and peaked at 12.1 psi boost. Now if I could just go up to 15 psi.....
Posted on: 2006/9/25 8:19
Lifes good when your on BOOST!
Re: Finally, the beast has been tuned!! |
From Sydney , NSW
BAAAAAAANNGG !!! Cheers
Posted on: 2006/9/25 8:36
Ha Ha Ha. Who had the big grin driving it there? What was the L series making?
Posted on: 2006/9/25 9:28
i thought blood was supposed to be thicker than boost?
are you runningblow thrpugh set unp dog160 or efi?
Posted on: 2006/9/25 23:30
From Canberra
120hp thats pretty good. I think it made 70hp with 120fly on an a12. Is that still with the decomp plate?
Posted on: 2006/9/25 23:44
From Ipswich,QLD
hell yaeh the torque factor was quit impressive when i used it it pulled like 10 men ,third gear would wind out for ever .
Posted on: 2006/9/25 23:50
From Brisbane, Australia
that's not bad at all on a stock motor. Will be good to hear how it goes on the track!
imagine what it could do with a cam, some porting, maybe valves, and pistons that will handle more boost...
it that still with the old T3 on it?
Posted on: 2006/9/26 3:04
Unfamilia- The set up is a suck thru 1 3/4" SU and a Sigma turbo out to T3 spec. Tyrie- Yep, still has the decompression plate, it's the same as when I bought it! 120fly- You know how hard this goes Geoff!  3rd and 4th gear are where all the action is! And it is running a Stanza diff with 4.1 centre. L18 B110- Harry, it is still running the Sigma turbo out to about T3 specs. We toyed with cutting the flange off and fitting a T28, but this one has more top end, and is a T4 bolt pattern for if we get REALLY serious!(or stupid?)
Posted on: 2006/9/26 13:25
From perf
how much timing are you running?? i just had mine dynoed at 110 on 11psi and it has turbo pistons, cam, efi, t25/28.... very dissappointed to say the least
Posted on: 2006/12/7 19:53
From Perth
That sounds like a whole heap of fun to drive...... keep up the good work on those turbo's boys!
Posted on: 2006/12/11 17:48
