STANZA VS 120Y BRAKES
From Adelaide
Hey guys...
Im looking at getting disk brakes for the front of my datsun 1200 ute..
its gonna be the same prices to get either set.. stanze or 120y..
but the question is... i heard that the 120Y brakes bolt straight up
im looking at getting stanze coz there bigger..
do the stanza brakes bolt straight up?
im looking at the lot.. strut spring disc brakes.....
any info bout them... i have looked in the tech but i want you opinions...
cheers
Posted on: 2006/9/28 2:04
Re: STANZA VS 120Y BRAKES
From Gold Coast Australia
I know it doesn't answer your question directly but I am going for 120Y struts on my sunny as Kev Rowly makes an adaptor plate to fit SR20 Silvia disks and calipers to the 120Y strut (I am doing an SR20DET conversion).
I am assuming that you have an a series motor so the 120Y disks would be fine but I thought I would let you know about the silvia thing because if you ever wanted to go for a CA or SR conversion, upgrading your brakes would not be a problem.
Posted on: 2006/9/28 2:39
SR20DET Sunny for sale, click me for details
From Geelong, Vic
for stanza struts, you will need stanza control arms and such, which will end up increasing the track width a bit
in standard form stanza brakes are alot better than 120y ones, but depends if you are going to upgrade to bigger brakes
you can use landcruiser 4 piston calipers on stanza struts, then just need to find some discs to suit
main advantage of 120y struts is that they will bolt straight in and you keep the same track width, if it was me using 120y struts the brake upgrade would be the first thing on my mind
im using stanza struts, well was, now using 200b struts pretty much the same but shorter (need to change spring perch also)
and will soon be running the landcruiser 4 spots, but ive changed brakes 3 times without driving the car, i just want big brakes
hope that helps
Posted on: 2006/9/28 2:41
From Adelaide
Im going with a A15... i reckon the 120Y brakes be fine.. get a new disk and new pads.. she be prefected for it..
what should i get of the 120Y car then...
struts brakes caliper!!!!
should i just undo the four blots on top and then undo the control arm and steering arm.. so then it just bolts straight in when i get home..
cheers
Posted on: 2006/9/28 2:46
From Geelong, Vic
try to find a late model 120y with girlock calipers, better than the early model ones
from the 120y you only really need to unbolt the strut and i think thats about all you need (with brakes still attatched obviously)
then get some new flexable brake lines made up
need to change your mastercylinder from drum drum to dics drum, or just take the 120y master
also need to change rear wheel cylinders to 120y ones
unbolt the three bolts on top and the 2 under the steering arm, then you need to change the 120y strut top for the 1200 one as the 120y one will raise the car
then bolt them into the ute
Posted on: 2006/9/28 2:53
From Adelaide
yeh u just take the pressure thing out the front master so it works for a disk.. i looked that up..
why do i need the rear wheel cylinders to 120Y??
and how late do the 120Y's go to..
cheers
well im i gotta go to work now.. but ill be back on at like 4.30.. to talk sum more to ya pigdog.. ur helping alot with this.. thanks
later
Posted on: 2006/9/28 2:57
From Geelong, Vic
120y rear wheel cylinders are smaller, and help to stop the rear locking up when you have discs up front
dont really know what year model they are, but i think its like 76 or something maybe later
someone else on here should be able to tell you
Posted on: 2006/9/28 3:04
From Adelaide
oh ok cheers....
does anyone no wat yr is best to get my front set up from a 120Y....
thanks
Posted on: 2006/9/28 7:50
From Rocky Queensland
i got the 77 120y front end for mine. they are PBR calipers tho. havnt put them in yet cause i still dont have my ute. ill be doin a CA conversion as soon as it gets here tho. so abit unsure on if i should go bigger. only being used for street use. maybe a few 1/4mile runs to get times but thats it.
Posted on: 2006/9/28 8:59
From Geelong, Vic
ok need to find one later than july 76, they have the better brakes, PBR is probably right
Posted on: 2006/9/28 10:52
