Browsing this Thread:
1 Anonymous Users
Re: How low have you gone? |
From Canberra
what do the reset leaf brigade do about shocks? get shorter ones or just have them compressed more? I've never had a problem with blocks, the bumpstops are built to absorb the shock somewhat. With 3" blocks in my 720 the issue isnt hitting the bumpstops its stopping the tyres rubbing under the tray. However with flipped leaves and no bumpstops (read axle resting on chassis) The ride is less than comfortable
Posted on: 2006/9/30 10:43
From Geelong, Vic
well as a member or the reset leaf brigade, in the sedan the shocks are going to loose travel any way you lower it (i have a sedan), so ill have to find shorter shocks or just see how the stock ones go
and i can flip leaves by myself to lower my car, cost nothing
Posted on: 2006/9/30 11:26
From Perth WA
Flip leaves yourself? How do you get them back into the clips/holders? That was about the only thing stopping me from doing it to the wags. Reset springs are too costly, for me anyhoo I went 2" lowering blocks on the rear and the good old 1000 self lowering on the front. The back is still 1" higher then the front!
Posted on: 2006/9/30 13:39
Chris... Show your love and join the black hole! CLICK
Re: how low have u gone |
From Logan,Queensland
i,ve got 3'' blocks in mine the 14'' tyre sits just in the gurd, Cops dont leave me alone every time i get pulled up ,,,your car is to low,,,but mine looks bad cause my front is still sta hight, doesnt handle at all, but i like the drag style look,i mostly do skids or cruze The ride is harsh i just keep an eye out for the bumps
Posted on: 2006/9/30 15:43
From Geelong, Vic
clips/holders? all that are on the 1200 leaves are the metal doovers that are on the second leaf, they bend easily
all you need is a vice ,some other clamps and a big rod to keep everything centred
Posted on: 2006/10/1 1:55
From Tamworth , NSW
how low have i gone?? i think sleeping with my ex's sister after we broke up was pretty low
Posted on: 2006/10/1 2:25
From Adelaide, SA the drift state
lol good one.
well i think ill just get 2 or 2.5 inch drop. its only 100 bucks so if the ride gets to un bearable then ill get proper stuff done.
Posted on: 2006/10/1 3:22
From Brisvegas, oz
what sorta price would it cost to get your leaves reset
Posted on: 2006/10/3 0:42
From Adelaide
i got 2.5 inch in my car already.. what would happen if i buy a 1inch and put it on top or on buttom.. would it full out?
Posted on: 2006/10/3 1:31
crzy_1200_ute just undo your springs and let it sit on the bump stops cause i know with mine there is jack s@#t room from the diff to bumps. You could cut the bumps in half or some thing to get some travel?
Posted on: 2006/10/3 2:34
