#1 How beefy is the Hilux LSD?
sundat1200 Posted on: 2006/10/3 10:41
We have a dead '74 Toyota Hilux here and I'm thinking it may donate its rear end into one of our 1200's. How much abuse would it take? I see that there's a rally car or two with one of these but I don't know if they use the stock LSD or what.
Basically I want to know how the LSD would hold up to constant abuse, say at regular drifting events. I know the rest of the diff is real strong, I just dont want to end up with an LSD thats worn out and not rebuildable or replaceable.
#2 Re: How beefy is the Hilux LSD?
Cameron_Datto Posted on: 2006/10/3 10:49
The hilux diff is super strong , i would be very surprised to break one in good order with a HI HP turbo 6 cylinder , the down side they are a heavy diff around 80kgs compared to 45 kgs for a h165 ute diff ,
#3 Re: How beefy is the Hilux LSD?
PIGDOG Posted on: 2006/10/3 10:49
ANGE has one in his ute, came out of LAGWAGONs CA1200, they might be able to varify that its up to the abuse
#4 Re: How beefy is the Hilux LSD?
sundat1200 Posted on: 2006/10/3 10:55
whoops, didnt mean to double post.
#5 Re: How beefy is the Hilux LSD?
I know its a strong diff. I'm asking about the LSD in the diff.
How will the LSD hold up? Are parts available to rebuild or replace the LSD?
#6 Re: How beefy is the Hilux LSD?
oan878 Posted on: 2006/10/3 10:56
My mate has 410 hp at the wheels in his ute and it runs low 10s. he also does half 1/4 mile skids in it all day. with slicks too.
The hilux lsd has hold up for 3 years now. so they are stong.
#7 Re: How beefy is the Hilux LSD?
sundat1200 Posted on: 2006/10/3 10:58
Dang, so all Toyota Hilux pickups have this diff? I'm stoked. I wonder how big the ring gear is.
#8 Re: How beefy is the Hilux LSD?
oan878 Posted on: 2006/10/3 10:59
you can get a wide range of ratios.
#9 Re: How beefy is the Hilux LSD?
sundat1200 Posted on: 2006/10/3 11:03
I'm curious how big it is in comparison to the stock diff. It sounds like its closer in size to a ford 9" or something if it can handle that power.
How wide is it in comparison to the stock axle housing?
#10 Re: How beefy is the Hilux LSD?
oan878 Posted on: 2006/10/3 11:20
the 1970 hilux is about 1275cm wide the newer ones are a bit wider. they all have the same size centres.
the arn't as bid as a ford 9inch.
