Browsing this Thread:
1 Anonymous Users
Re: R31 Skyline diff |
From Brissy
i think john taylor is the guy from one of the pedders down in nsw.... he makes up the leaf springs for the rear which are supposed to work quite well without any tramp......
Posted on: 2006/10/11 1:16
From Canberra
BAD310, Good luck getting the 4 link engineered in QLD, Have you had the design approved by QLD transport yet?? if so i would love to see the application and approval for my own project (save a bit of paperwork).
Engineers in QLD can not approve rear suspension design and a 4 link conversion fits into that category. Once the design is approved by QLD transport the engineer can approve the modification in accordance with the design.
Posted on: 2006/10/11 7:34
From Canberra
correct me if I'm wrong but BAD310's looks like its set up for a standard B310 2-link rear...
Posted on: 2006/10/11 8:13
From Gold Coast Australia
I always thought it was a four link because it has the four trailing arms, so what makes it a 2 link? You learn something new everyday
Posted on: 2006/10/11 9:28
SR20DET Sunny for sale, click me for details
From Canberra
thats a good point... I was told it was a 2-link, and thats where my knowledge ends
Posted on: 2006/10/11 9:34
Is there anybody out there who can verify if a standard B310 sedan's diff setup is a 4link or a 2link and what the difference is between them? I don't want to go around telling people that it is a 4link and it's not.
Posted on: 2006/10/11 9:40
From Melbourne Vic
i dont know what the 310 suspension looks like, but if it has two trailing arms that run where a leaf spring would, and two diagonal arms running from the diff to the body then its a four link. I believe a two link is accompanied by a panhard rod??? take a photo, if it has four 'links' its a four link tho
Posted on: 2006/10/11 10:19
CA18DET 1200 lagwagon retired LAG510 - SR20DET 1600 sedan 1000 wagon daily - A series magic
From Canberra
Sorry BAD310 you are probably ok. I'm not sure if the 310 has a 4 link or not. If you are connecting the suspension members up to the original mounts then you should be ok. I had a brain fart and thought you were converting from Leaf spring to 4 link.
Posted on: 2006/10/11 11:14
From Brisbane
looks the same as a stanza 4 link with coil springs
Posted on: 2006/10/11 12:53
From Adelaide, Australia
you can swap stanza and sunny rear ends. yes that is 4link.
Posted on: 2006/10/11 13:55
cheap + fast = disaster fast + reliable = expensive cheap + reliable = stock IPRA Build
