Re: Low compression
From Adelaide, Australia
My partners A14 compression tests at 125lb across all four, it has a fresh rebuilt head but rings are nackered and its a slug sometimes when its warm. Add oil and shoots up to around 180lb.
DDgonzal, he should see 175lb, that just means it is a fresh engine. factory rebuilt should be just above 180lb, factory min, ie. needs rebuild is 145lb.
Posted on: 2006/10/17 9:12
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
« 1 (2)
