(1) 2 3 »
#1 can an L series 5 speed bellhousing be exchanged for an a series 4 speed
woody Posted on: 2006/10/19 2:47
im just wondering if anybody has done this as im looking to do it. does anybody know if this is even possible?
what model can i get a 60 series dogleg box from. my understanding is sss models and 1600's.
also does anybody know the ratios of the 60 series 5 speed dogleg box?
thanks kurt
#2 Re: can an L series 5 speed bellhousing be exchanged for an a series 4 speed
sidedraught Posted on: 2006/10/19 2:58
I would say no because the bellhousings dont unbolt on an A series 4 speed, they are cast as one with the gearbox housing.
#3 Re: can an L series 5 speed bellhousing be exchanged for an a series 4 speed
woody Posted on: 2006/10/19 3:02
thats what i ment could i swap the whole front section onto the 5 speed as all of the vital bits are in the wrong place for an a series
#4 Re: can an L series 5 speed bellhousing be exchanged for an a series 4 speed
pager Posted on: 2006/10/19 3:08
I say anything is possible. With a welder and grinder many things can be done.
#5 Re: can an L series 5 speed bellhousing be exchanged for an a series 4 speed
TnPshow Posted on: 2006/10/19 3:10
Id say maybe. However, I'm not 100% sure any L-series had a 60 series box? Anyone?
63A - yes (stanza SSS etc), but good luck finding a 63A 4 speed bellhousing for an A block...
...and no, 60A isn't compatible with 63A as the 60 and 63 signify the distance in millimetres between the two main shafts in the box.
edit - I'd like to know if the L's had a 60A 5 speed cause I've got a spare 60A a series bellhousing laying about
#6 Re: can an L series 5 speed bellhousing be exchanged for an a series 4 speed
Mildman Posted on: 2006/10/19 5:17
Well A series boxes do come apart.
But half the gears reside in the bellhousing side of the box.
#7 Re: can an L series 5 speed bellhousing be exchanged for an a series 4 speed
A14force Posted on: 2006/10/19 8:53
You could fit an l series box to an a seires front half, But you would need to start with an a series 63A bell housing/front section.
I just today scored a 63A five speed box, for an a series. They are kinda stumpy. I only paid $350NZD for it. (Yeah, I am gloating)
If you had the gear it would be possible to cut off an A series bellhousing, and tig it onto an L series box. But you'd need to know your stuff.
#8 Re: can an L series 5 speed bellhousing be exchanged for an a series 4 speed
olboy Posted on: 2006/10/19 9:32
Just a thought but an A series auto box has a separate bell and I think they are flat on the gearbox end so another box should be able to be bolted on the back.
#9 Re: can an L series 5 speed bellhousing be exchanged for an a series 4 speed
TnPshow Posted on: 2006/10/20 0:14
Another box yes, but not an L series.
I've done this with a Toyota T50 box.
Just have to iron the bugs outta the clutch and I'll share it with everyone else!
TC
#10 Re: can an L series 5 speed bellhousing be exchanged for an a series 4 speed
woody Posted on: 2006/10/20 0:49
so from what im gathering a sss stanza uses a 63 series box?
does a 1600 use the 60 series?
thanks for all your help i need more umph in the hillclimb that i will be doing plus an overdrive coz the A15 is a bit mean around town and on the highway
(1) 2 3 »
