Browsing this Thread:
1 Anonymous Users
crankshaft end play for a ca18det?? |
From Costa Mesa, CA
i need to know the maximum play aloud.. ? .5mm? thanks..
Posted on: 2006/10/21 1:15
Re: crankshaft end play for a ca18det?? |
From Costa Mesa, CA
also can i get the torque specs on the rod caps? thanks..
Posted on: 2006/10/21 1:43
From Brisbane, Australia
Standard: 0.05mm to 0.18mm (0.002-0.0071 in)
Limit: 0.3mm (0.012 in)
Straight from the manual.
Posted on: 2006/10/21 1:48
Torque rod caps in 2 stages. 12ft-lb and then 33 ft-lb. Have a look here: PDF Manuals
Posted on: 2006/10/21 1:50
alright, spill the beans, did you put stronger internals or are you rebuilding the motor to stock?
Posted on: 2006/10/21 5:19
From Costa Mesa, CA
thanks cabletie.. my motor is making some bottom end noise, so we pulled the pan and checked bearings etc. too much play in crank. .55mm sucks! just changed the headgasket to a comedic one also. oh well..
Posted on: 2006/10/23 21:51
