Browsing this Thread:
1 Anonymous Users
brake booster |
From Adelaide, SA the drift state
hey guys,
im gonna use r31 brakes setup and just wondering if i can use the orig booster or do i need a new one.
cheers patts
Posted on: 2006/10/24 10:36
Re: brake booster |
From Geelong, Vic
original booster should be fine, the brakes dont know the difference
Posted on: 2006/10/24 10:40
Re: brake booster |
so theres no differnce at all
well that helps the budget
cheers, patts
Posted on: 2006/10/24 11:02
Re: brake booster |
From Geelong, Vic
there is a difference, there is no way you will fit a bigger one in nah there will be a difference, but i assume you have a 120y booster, should do the job fine
Posted on: 2006/10/24 11:08
Re: brake booster |
um its just a plan 1982 ute booster.
Posted on: 2006/10/24 11:23
Re: brake booster |
From Adelaide, Australia
What are you doing with your brake master cylinder mate?
Posted on: 2006/10/24 11:31
cheap + fast = disaster fast + reliable = expensive cheap + reliable = stock IPRA Build
Re: brake booster |
wel so far leaving it standard, will thois work
Posted on: 2006/10/24 11:34
Re: brake booster |
She'll be right mate, it should be tandem. Leave it for now, you might have trouble if your pads get real low, you can get yours bored out the same size as the r31 master later on so it all fits up correct.
Posted on: 2006/10/24 11:41
Re: brake booster |
yeh its go the twin wells, so it should be good
Posted on: 2006/10/24 13:16
Re: brake booster |
From Canberra
I didnt know any utes came with boosters... 120Y booster
Posted on: 2006/10/24 23:09
