wot conversion ca18de or wrkd a15
Not too shy to talk
heya all jus wanna no wot would be better stock ca18de coversion or wrkd a15 conversion ............. 4 a 1200 ute
Posted on: 2006/10/27 23:45
Re: wot conversion ca18de or wrkd a15
From SE Melbourne
If you are staying non turbo go the A15, if you are turbo charging go the CA18DET. (IMO)
Posted on: 2006/10/27 23:51
Mildman, Datsunless
From Sydney, Australia
They cost about the same and you'd be paying less for petrol with the CA18DE and you'd have a 5 speed.
A15 is easier, CA18DE is better and cheaper.
Posted on: 2006/10/27 23:59
From Tamworth, NSW
Okay what is it DO CA18 conversions really cost 5000+ or not?
A15 ~$500 an depending on "wot" model ute you have have it will drop in. You will have to upgrade brakes but that should be it.
How do they cost the same?
search
this topic has been covered many times therefore there is heaps of info
Posted on: 2006/10/28 0:25
Project coupe:
Just drive it
From SE Melbourne
He did say 'worked' A15 so that's at least a few k there I assume with headwork, carbies, extractors, cams, rockers.
CA18 wouldn't be worked, stock, crossmember, fuel system and clutch are some of the expenses, plus a lot more mucking around.
With you on the search comment too pager - there are a few threads on this. If you use Google to search this site is does a better job than the forum seach engine too.
Posted on: 2006/10/28 0:33
Mildman, Datsunless
From Bunbury Western Australia
yep an A15 costs about $500, plus preparation, cam, head work, ignition, exhaust, carbs, tuning, fuel system, cooling system, diff upgrade (depending on how you drive it), brakes and all the small things that add up in between.
My A15 cost me almost $5000 from start to finish
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From brisbane, qld
Go the ca18de conversion. An a15 is ok but you can only get so much power.
Once you drive a ca for a while with its power and fuel economy a worked a15 seems a bit of a waste of time, plus you get a 5 speed, which you will appreciate.
When you are after some real power you will end up doing the ca conversion anyway, so if you already got a natural ca, it will be simple to put a turbo ca in.
Ive got a worked a15(twin 40's, cam, headwork,ect) and a ca18det powered ute and while the a15 sounds good and goes alright, Its got absolutely nothing on the ca version, and its pretty much stock except for a front mount and a split dump.
Spend your money on doing the ca conversion straight up, you'll save money in the long run.
Posted on: 2006/10/28 3:10
From Adelaide, SA the drift state
i say CA just because parts are easy to come by and you have the luxury of a five speed.
Posted on: 2006/10/28 3:12
From sydney
Get a worked A15 from someone who is doing the CA conversion, shouldnt cost much more than a grand all up , worked A15 has all the power a sane person would need in a 700kg sub compact, if you want to be blowing off WRXs and Porsches get the CA.
Posted on: 2006/10/28 3:36
From brisbane, qld
1 datsun 1200 - $3000
Ca18det front cut- $2500
Parts and consumables- $3-4000
The look on the face of some wanker who paid $50,000 dollars or more for a car you just blew the doors off-
PRICELESS!
Posted on: 2006/10/28 4:17
(1) 2 3 »
