Re: twin weber dilemmas, not running right
From Adelaide, Australia
I know your problem, your running an a-series!
Posted on: 2006/11/2 7:40
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Brisbane
Hey hey easy up on the Aseries ..... Im still a Big fan, if my future Lseries gives me less or same amount of minor problems my aseries did I will be a happy man
Posted on: 2006/11/2 7:47
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Wamboin near ACT(canberra)
ok well everythins hooked up, quick question, i have a malpassi regulator, the most pressure i can get it 2 run is 4 psi, thats fully adjusted down, is that normal??? 4 is ok, but just weird that i cant get it higher
Posted on: 2006/11/3 10:23
just talked 2 a mate, and he said its probably cuz of the stock fuel pump, is this correct, he said ya average pump, will be good for between 3-5 psi
Posted on: 2006/11/3 10:39
From Sydney, Australia
3 to 5 is 'Weber territory'.
2-4 psi would probably where I would expect it to end up.
Posted on: 2006/11/3 13:10
From Christchurch NZ
WhiteSedan wrote:
If you want a new pump, get a holley red pump, should come with a reg i think.
Holley red's don't come with a reg, They don't make enough pressure to need one. Blue's and Blac's do though.
Posted on: 2006/11/3 19:43
Forced Induction!
« 1 2 3 (4)
