Dodgeman wrote:
& how much lift do you have at the cam?
rally1200 wrote:
The lift i gave was valve lift. the cam spec sheet said .295" cam lift.
Yeah, I thought as much, but I did ask for lift at the cam & I went by your response.
I had always thought that an absolute minimum valve to piston clearance of .060" was required with .080" or larger prefered, depending on how much it revs.
Next time you have nothing to do, pull some plugs in the darkness of your garage & have a look at the pistons with a small diameter torch [flashlight] & try to see if there is any evidence of valve contact with the pistons, or even the bore if you are running big valves.
This is the only possible thing that I can think of that would make the noise that you mention.
EDIT. No, it's not the only possible thing, I just gotta learn to think more.
