« 1 (2) 3 »
Re: Your A series HP output?
Kale,
A14, aftermarket German pistons.
Standard bottom end
Lightened flywheel
Very nice head like Neils set up for velocity and quick throttle response.
The latest Kelford cam grind ( new generation profiles )
Twin 40's
4/1 ectractors
Electronic ignition
Run late last year on the dyno and produced 78.1 kw at the rear wheels @ just over 7000 rpm before dropping away quite sharply for various reasons that are in the process of being remedied.I believe that this equates to 104 hp and I would be confident that if we can keep the power curve linear for another 500 rpm then we should be somewhere between 110/115 at the rears.
Cheers
Dave
Posted on: 2006/8/25 2:25
yer cool anyone else got a worked a series tell us your specs and what power you are getting?
Posted on: 2006/11/9 14:32
From South East QLD
If you can make over ( fly wheel ) 100HP Per litre in Na 2 valve motor your doing well . So this means if you have a 1.5ltr x100 = 150hp at the flywheel
Posted on: 2006/11/9 15:52
From Bunbury Western Australia
I have an A15 with a ported head, competition valve springs, linished valves custom cam 240 degree, .475 lift, .085 intake overlap at TDC, bluebird electronic dizzy, 4-1 extractors and 2 1/2 inch exhaust, Weber 38/38 DGAS carb with choke removed for more flow and a Boshe HEC 715 coil
I am not sure of power output yet but I estimate about 90rwhp
Posted on: 2006/11/9 16:05
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From South Africa
A15
Stock head:
Langley Pistons:(20t over) (chopped 1.5mm off the top)
stock rods(another 1.5mm chopped here)
Stock Crank:
everything else in engine is stock.
Inlet manifold: Custom short tube (batch injection)
EFI: Gotech Std, Custom Dizzy.
Injectors: 295CC (4AGE), 4 of
Exhaust: Custom. 35mmID mildsteel TIG welded.
Turbo: Garrett T2 (0.43\0.45) 12blade shaft.
Boost plumbing: 50mm >> 63mm 308Stainless TIG welded.
Throttle Body: 51mm (Toyota whatever... :) )
Exhaust: 63mm 308SS tigwelded, one muffler.(Db @3500Rpm=78.2)
tested by some hyperactive COP the other day.
@14psi boost (we have some real crap fuel here)
HP =?????????
Torque=??????????
G-tech say it's 185Hp.... but yes I'd love to believe that....
Posted on: 2006/11/9 16:27
From Tracy ,Ca
170hp at the crank
a12 block 76mm bore and oringed deck
a14 lighten crank
a12a rods custom pistons
14-1 C/R
a12gx head ported
40mm intakes 33 exhaust with 7mm stems
twin mikunis
292degree cam
114 octane race gas
redline 9200rpm
installed in a 1400lb 1200 coupe
Posted on: 2006/11/9 16:31
From In front, and pulling away.Sometimes around Sydney....ish!
A14 standard with 3mm decompression plate. Stock bottom end and head. T3/T4 turbo suck thru with 1&3/4 in SU. 12psi with 3 inch exhaust. 90.4 rwkw (121.3 rwhp.) in 800kg Sunny
Posted on: 2006/11/9 17:02
Lifes good when your on BOOST!
From Stray-ya
I'm sure this thread's been done before, but what the hell
A-15
light port& polish, stock valves, pistons rods etc,
30/70 cam
32/36 DGV weber
72 hp at the treads
Posted on: 2006/11/9 17:39
From The garage, NZ
STOCK everything, reset timing, reset point gap etc.
never been on dyno but factory rekons 69 @ 6500 lol
not for long tho.
Posted on: 2006/11/10 2:51
From San Jose, California
I'd love to know what a stock A12 makes with some bolt on's like a header and a single sidedraft. That's what I will likely run in FSP SCCA autocross soon because of the rules and my pocketbook.
Posted on: 2006/11/10 5:53
-Daniel
« 1 (2) 3 »
