#1 turbo
davos Posted on: 2006/11/15 18:59
if i wanted to put a turbo in my 1200 datto would it be pointless ?? if not what size should i use
#2 Re: turbo
matty Posted on: 2006/11/15 19:56
It would only be pointless if it's a poorly designed set up that causes more problems than it solves.
Turbo size depends on what motor you are planning on building.
If you do a search on this site you will find pages of information on turbocharging an A series, CA18DET conversions etc.
Topgear recently had a lot of success in turbocharging an A series motor so have a look for his posts in particular.
Regards Matty
#3 Re: turbo
dog160 Posted on: 2006/11/15 20:18
Davos, do it man, you won't regret it! Done properly, they are very streetable and lots of low tech fun! If you want the easiest way a suck thru is the best. Standard fuel pump on mine (A14) and makes 90 rwkw. If you run a blow thru set up, you can intercool it, but will need high pressure pumps, similar to efi.
