« 1 (2) 3 »
Re: are car, ute, and sedan leaves the same?
From Perth
Anyone know if 1000 and 1200 springs interchange ?
Someone does decent coupe rear springs for 1200's and I wonder if they will fit my 1000 coupe
Posted on: 2006/11/16 21:43
I would imagine you can use your 1000 top leaf ontop of the 1200 leaves, I have never dont it with 1000/1200 but i have seen a 1200/120y combo.
Posted on: 2006/11/17 4:26
From Darwin NT
ill compare 120y ones against my wags and ill see if they are interchangeable
Posted on: 2006/11/17 4:59
current project 4x4 patrol...
From Cape Town ZA
Here is a comparison between the UTE and Sedan blades. The top ones being the UTE ones. They are noticably beefier
Posted on: 2006/11/20 5:40
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
From Christchurch NZ
Thanks!
Beefier yes, but the same lenght none the less. Are they the same width?
Posted on: 2006/11/20 16:14
Forced Induction!
Bart got ute ones here as well!!!!
Posted on: 2006/11/20 16:34
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
Is the width the same?
Posted on: 2006/11/21 16:36
Forced Induction!
From Brissy
yes the width is the same on the sedan, wagon, coupe and ute...
Posted on: 2006/11/21 17:09
Do you want both sets? As I am thinking about heading up your way this weekend, maybe, not totally sure as yet still waiting to hear back from another guy about some bits
Posted on: 2006/11/21 17:49
From Cape Town ZA
Exactly the same width, same shackle rubbers as well, only the thickness is different where the u-bolts go. One should get slightly longer u-bolts to make them fit properly, otherwise the nuts only catch with a few threads initially, and they might strip before you tighten them all the way.
Posted on: 2006/11/21 19:12
1200 GX Sedan
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
« 1 (2) 3 »
