stanza struts
Quite a regular
From sydney
im just about to install a set of stanza struts and im just wondering, when i bolt them up will i have to do any modifications to the master cylinder and also do i have to change the wheel cylinders.
and yea ive checked the history, its not very clear cut.
also any help with camber and handling would be greatly appreciated
cheers
Posted on: 2006/11/22 10:45
Re: stanza struts
From Geelong, Vic
you will need
twin reservoir mater cylinder set up for disc drum
and smaller rear wheel cylinders(out of a car with disc front)
your car might already have twin master set up for drum drum, there is debate about whether this needs to be changed
help with camber and handling??? the struts should help with both of them
Posted on: 2006/11/22 10:52
Re: stanza struts
From Melbourne, Australia
no need to change master or wheel cylinders
handeling and stuff... depends how willing you are to lip guards and bend them out
but good to relocate the lower control (use 1200 ones) arm mounting point further out on the engine crossmember to get some good negative camber.
you need shorter springs aswell otherwise you will be pointing skyward
could also add an extra 10mm thread to castor rods (120y ones required) to get extra castor
you can use the 1200 top spring plates to go straight in, or use stanza tops and have to enlarge the holes in the strut tower
use 1200 inner tie rod end and steering rod and stanza outer tie rod end
you can undo the top of the strut and tip out the oil, measure it (about 250ml) and put in 20-50 motor oil to stiffen up the shocks also
edit: posted at same time, do you have drum front now or disc??? if you have drum front then you do need to change or modify master as suggested
Posted on: 2006/11/22 10:53
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: stanza struts
Quite a regular
From sydney
its 1980 ute so its twin resvoir
i was thinking of just putting the struts in with the stanza lca's and caster rods and hopefully i wont have too much of a problem with + camber.
so is there anything else i got to do besides get new rear wheel cylinders from a 120y or something.
Posted on: 2006/11/22 10:59
Re: stanza struts
pretty sure you need 1200 lca's and 120y castor rods...
Posted on: 2006/11/22 11:16
1200 Coupe Rallycar
