Re: wiring harness part number
bigg, you talking about the Red 1200? It's a decent wiring harness, there are only two problems I noted:
- typical corrosion on the lamp sockets. That should be able to clean up fairly easy
- A ground problem (that we worked on, and seemed we fixed it). Symptoms: Some gauges worked, others didn't, but when you turn blinker, the dash lights came on (wrong lights), etc. It started working correctly when I pushed in the connector on the back of the dash.
Getting a new harness most likely won't solve a ground problem. It needs to be tracked down and taken care of.
Posted on: 2006/11/23 0:44
Subject Poster Date
     wiring harness part number biggc2 2006/11/22 1:03
       Re: wiring harness part number B210sleeper 2006/11/22 1:53
         Re: wiring harness part number biggc2 2006/11/22 6:12
           Re: wiring harness part number biggc2 2006/11/22 21:40
             Re: wiring harness part number B210sleeper 2006/11/22 21:52
               Re: wiring harness part number ddgonzal 2006/11/23 0:44
                 Re: wiring harness part number biggc2 2006/12/5 14:59
                   Re: wiring harness part number ddgonzal 2006/12/7 16:45
