#1 electronic distributor for an A 14 Motor
Sakkie Posted on: 2006/11/23 14:19
DOES ANY BODY KNOW OF ANOTHER DATSUN ELECTRONIC DISTRIBUTOR THAT WORKS WITH AN A14 MOTOR ??
#2 Re: electronic distributor for an A 14 Motor
3Rotor Posted on: 2006/11/23 16:10
I've converted a std points dizzy to hall-effect, ... nothing to it..
damn..... finding the link to the thread is more complicated...
#3 Re: electronic distributor for an A 14 Motor
3Rotor Posted on: 2006/11/23 16:12
#4 Re: electronic distributor for an A 14 Motor
Dodgeman Posted on: 2006/11/23 19:42
Other than what?
Some have used the whole distributors from Nissan E13 & E15 engines & these are a fairly easy conversion requiting little more than the instalation of an A series drive gear on the distributor shaft. Pertronix make a conversion that simply replaces the points &
this is what 1200GXman has in his 1200 &, since last week, so do I in my 1200.
Instalation is simplicity itself & I don't know of anyone who is unhappy with theirs.
#5 Re: electronic distributor for an A 14 Motor
mad120y Posted on: 2006/11/23 22:16
I did e15 dizzy on a12. It was honestly easy as.
1. Just push the pin out on the gear on the a series dizzy, take off the spacer on the e15 dizzy.
2. Put the a12 gear on the e15 dizzy and drill hole.
3. Put in the pin through the gear.
4. Modify plate to suit a series.
5. Wire up.
6. Set timing.
7. Drive
