« 1 (2)
Re: flat top pistons vs std
DatsunSSS will post a picture of *one kind* of A12GX piston.
Same part number == same part.
The Datsun A12GX engine came with two different pistons:
* High compression: same piston as A10 engine.
* Low compression: a unique piston
It seems that they first used the B10 piston,then for some reason the number was changed.
That happened to almost all Nissan part numbers. It doesn't mean a lot in this context. It just means that the later A10 engines came with the updated A12GX piston (H23xx is the Datsun 1200 GX model).
Again, 12010-H1001 was the "normal" A12 piston set. It was also used by the "low compression" A12GX.
It seems we have "discovered" a whole new source for high compression GX pistons -- I knew it was just a matter of time before we would find a good use for A10 engines.
Posted on: 2006/11/26 22:22
Not too shy to talk
From Ronse,Belgium
Well I just think he would have pistons originating from an A10 engine.We didn't get anything GX here,so I had no knowledge of these engines having the two types of pistons.Due to taxes and high fuel price (even then) the A10 engine was very common and easy to find here,and the swap in A12 engines has been known since the early seventies.I thought that since the car had a special gearbox and LSD,there might have been a full spec engine in it with the 76.8mm pistons to bring the engine to 1298cc.Seems DatsunSSS wasn't that lucky.....
Posted on: 2006/11/27 2:30
I've been saying for years that ate A10 pistons were all the go for 1200 engines. This is what I used when I built the 1200 engine in my wife's green 1000 two door.
The new pistons were the same price either way, so it amounted to a little more compression for free. Ran real nice too.
Posted on: 2006/11/27 7:23
Love your Datsun.
Treat it well.
From Portugal
Finally.
Posted on: 2006/11/27 19:16
From Portugal
any opinion?
Posted on: 2006/11/28 12:39
From South Africa, Bloemfontein
The genuine GX pistons are not completely flat.
I know because I have a spare GX engine and I remember when we removed the GX cylinder head of the car's engine that they looked the same as my spare GX engine.
It has a small step in the centre of the pistons. The step starts at about 10mm from the edge of the piston. Is anybody interested in a picture of it?
Let me know and I will take a quick pic tonight and post tomorrow.
Posted on: 2006/11/28 12:54
1977 Datsun 1200GX
From Portugal
that is the standard datsun 1200 piston.
My doubt is about having two types of gx pistons.
im trying to find if this piston is from one datsun 1000 or a datsun 1200 gx.
Posted on: 2006/11/28 21:18
Not too shy to talk
From Ronse,Belgium
Those are standard A10 pistons.
Posted on: 2006/11/28 21:49
From Tracy ,Ca
back in the Eighties I got two gx motors from Japan both never been apart found both had flat tops in them
Posted on: 2006/11/29 2:56
« 1 (2)
